ports
Troncoso
i cant remember at all, where to go to open or block ports. either somewhere in internet options or firewall...maybe not. can someone help?
on my computer. i'm using xp. i need to unblock port 25 i think it is for email..25, 110, and 143, isnt it for email ports?
Yes they are all email ports. Do you directly connect to the internet from your computer or via a Router/Modem ? If you connect via the router/modem you will need to check on there for any port restrictions.
The port blocking and unblocking all occurs in the modem / router.
not true. ports can also be opened in firewalls. because all you are doing on the router is opening ports on its hardware firewall.
if you are using a router you will need to type the IP of the router into a browser (usually either 192.168.0.1 or 192.168.1.1) and configure it from there.
if you are using windows firewall you can go control panel-> windows firewall -> exceptions -> add port and enter them in there.
