Rate my build
VicP712
I am ordering it today if I get the OK from Computer Forums of course :D
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135156
ASUS 20X DVD:$35
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148136
Seagate 500GB HDD:$80
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009094
Acer 22Inch Monitor:$220
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130318
EVGA 8800GT 512: $209
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182032
Rosewill PSU 600W: $70
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
Corsair 4gb:$85
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
Intel Q6600 Quad 2.4:$214
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
Arctic CoolerCPU Cooler:$27
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
Gigabyte P35 Mobo:$109
Case: suggestions please!
Total without case is $1051
My only need is a suggestion for a case. My budget is under $100. My main concerns are cooling and low noise. Let me know what you guys think!
Grand total should be under $1200. If I am under budget I want to get a soundcard, it must have Optical hookups. Let me know!
great choice on the monitor, i have the same one. itll perform very well and youll be very happy with it :)
im not really loving the ram, it might not overclock too well considering its stock timings are 5-5-5-18 at only 800mhz.
also i dont see an operating system there? but i'll go ahead and assume you already have one.
The case i would recommend most is this one, its not expensive at all and reviews on other websites are awesome: http://www.newegg.com/Product/Product.aspx?Item=N82E16811167001
What ram would you recommend around $85?
I also got Windows Vista Business free from my schools business department
i like oscaryu1's choice of ram, Corsair is great for the price point.
have you decided on a case yet?
