ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler
dak1b
Model
Brand ARCTIC COOLING
Model Freezer 7 Pro
Spec
Type Fan&Heatsinks
Fan Size 92mm
Compatibility All Intel Celeron (Socket 775)
All Intel Pentium 4 (Socket 775)
All Intel Pentium D
All Intel Core 2 Duo
Core 2 Extreme Quad
RPM 900 - 2500 RPM(PWM)
Air Flow 45 CFM
Noise Level 0.9 Sone
Power Connector 4 Pin
Color Black
Physical Spec
Fan Dimensions 107.0 x 43.5 x 96.0mm
Heatsink Dimensions 104.0 x 58.0 x 126.5mm
Weight 520 g
Features
Features Extremely Quiet
Powerful cooling
Integrated Cooling of Voltage Converters
Patented Vibration Absorption
Easy Installation
Manufacturer Warranty
Parts 6 years limited
Labor 6 years limited
Whats ur guys feedback/opinion on this product?
i purchased one to replace my crappy Akasa LGA 775 cooler.
Its very quiet even running at 100%,However i still get high tempratures with this cooler but i think it might just be that it needs some new thermal paste.
its a good price,I would however recomend spending that bit more and getting a Zalman or a Scythe Ninja instead :)
i dont think the AC7 pro is anything to shout out loud about :)
It's a good cooler for the price, but it's not exactly that quiet as the heatsink needs high airflow to force air through the extremely tight fitted fins.
ok cool. i was looking at the Zalman. looks pretty sweeeet:D not too bad of a price difference either.
