New case.
Tuffie
I want to find a case that would look good with these: http://www.mnpctech.com/spdprtToggle.html
Anyone got any good suggestions for a good with the following features
Work well with those switches^^ (Basically means it cant have a door that closes onto where they will go.)
Needs a window
Doesn't have to but if it comes with fans with LED's that would save me some cash (I'm going to install Cathodes and fans with LEDs..)
No stock PSU. (I just hate wastage.)
Theres probably other stuff I will forget but yah.
Tuffie.
srry if this sounds rude but isnt the whole point of modding to create a case that does exactly what you want
Did anyone notice that the newbie with 200 posts was the only one to suggest a case?
Because everybody knows that one's level of reading comprehension, problem solving abilities, experience with computers, and netiquette can be directly related to how many posts he or she has made on one computer forum.
I would dissagree, I would say that post count just shows the amount of time you have been at CF.
Anyways I am now looking at the "Smilodon Extreme Black" do you guys think those switches will work?
If I find a case that looks better then that I'll be happy.
Kent.
I doubt you can fit those switches in the Smilodon, it has a front panel door...
Get the Lian-Li PC-7B ;)
That's so plain.. I don't know, I just think I would want to commit suicide it that was what my pc looked like :P
What do you guys think about the thermaltake armour?
Kent.
Kent.
Check out the Thermaltake Shark,
And that Lian Li case is fantastic, it's a lot classier than all of the other cases mentioned before.
Classy, but I think I'm looking for something with pretty colors, flashing lights, and shiny things! I mean it's so dull and boring.
Thermaltake Shark looks pretty cool, but the door looks like it will cover the switches.
Kent.
