Upgrading My Ram In My Laptop - Help? Advice?
Pauly73Drifter
Hi guys,
I have just purchased a HP Presario V3000Z Laptop with the AMD Turion 64 X2 Mobile Chipset and it has 1GB of Ram.
I want to upgrade to 2GB.
Here is the link to some info I found about the laptop and ram specs: http://www.ec.kingston.com/ecom/con...00Z+Series+(CTO)&distributor=0&submit1=Search
The questions are:
Is 2GB the max this laptop can take?
Is the DDR2-677 ram the right one/size that I need?
How hard is it to upgrade the ram myself?
I have built desktop pc's before but never laptops. Is the process of upgrading ram in a pc similar to a laptop?
Turn off laptop, take out battery, touch un-painted metal to eliminate static from your body, take off bottom plate ram cover, pull out existing ram (undo the clips), insert new ram, put plate on, battery in and turn it on! Is that the process?
I just want to know so I don't screw my laptop as it is my first laptop. Is there any process after that? Such as, programming ram, erasing ram or anything like that? Or is it just basically plug and play?
All help and advice is highly appreciated! Thankyou guys so much!
Pauly73Drifter
The questions are:
Is 2GB the max this laptop can take? Yes
Is the DDR2-677 ram the right one/size that I need?Yes
How hard is it to upgrade the ram myself?Easy.
I have built desktop pc's before but never laptops. Is the process of upgrading ram in a pc similar to a laptop?Yes.
Turn off laptop, take out battery, touch un-painted metal to eliminate static from your body, take off bottom plate ram cover, pull out existing ram (undo the clips), insert new ram, put plate on, battery in and turn it on! Is that the process?Be sure to take off the a/c power plug.
I just want to know so I don't screw my laptop as it is my first laptop. Is there any process after that? Such as, programming ram, erasing ram or anything like that? Or is it just basically plug and play? Plug and enjoy
Welcome.
