Hello,
I am currently using an HP pavilion a1310n to play WoW on over the summer. I can run WoW on default settings and it looks okay, but the FPS could be better. I will only be able to play for the summer though, so I am not looking to spend a fortune upgrading. I am looking at this card at the moment http://www.newegg.com/Product/Product.aspx?Item=N82E16814150247.
I have looked at reviews and it seems to be good, but I need to know whether this will for sure fix my FPS problem, and that there may not be a deeper issue here such as memory or processing power.
Some current specs (these are the ones I know how to get to, if you need more, just ask and tell me how to find them):
AMD Athlon 64 3700+
1 GB RAM
ATI RADEON XPRESS 200
Thank you in advance
AMD Athlon 64 3700+
1 GB RAM
