Looking for a new laptop (for school... mostly)
Aaronmcc
This is my first post and I'm still new to a lot of the computer tech information stuff but I've been trying to do a lot of research lately so I can sound like I know what I'm talking about (That's the important part, yeah?).
This is all starting because for graduation from High School, my parents will put $1k toward a laptop and allow me to pay the difference if it's more (I'd be ok with paying $2k for a total of $3k). I'm customizing my laptop but have a question about the processor. I'm planning (may change in 6-8 months for graduation) on the processor Intel® Core™ 2 Duo Processor T9500 (2.6GHz/800Mhz FSB, 6MB Cache). I've been looking at the tech requirements of some more involved games in order to see what a good processor is and I came across one suggesting a 2.8Ghz. Is that a single processor running at 2.8GHz or two? I believe (but I could be really wrong) that the processor I am thinking about is TWO processors each running at 2.6GHz with 6MB cache divided up between both of them (which would be like a 5.2Ghz processor? ish) . Would this processor be able to do the recommendation of a 2.8GHz processor?
Here is a list of the tech requirements I am looking at:
PROCESSOR: Intel® Core™ 2 Duo Processor T9500 (2.6GHz/800Mhz FSB, 6MB Cache)
OPERATING SYSTEM: Genuine Windows® Vista Ultimate Edition SP1
LCD AND CAMERA: Full Hi Definition, glossy widescreen 15.4 inch LCD (1920x1200) & 2.0 MP Cam (built in)
MEMORY: 4GB Shared Dual Channel DDR2 SDRAM at 667MHz (2 Dimms)
HARD DRIVE: Size: 250GB 5400rpm SATA Hard Drive
INTERNAL OPTICAL DRIVE: Slot Load DVD+/-RW (DVD/CD read/write)
VIDEO CARD: 256MB NVIDIA® GeForce® 8600M GT
WIRELESS CARDS: Intel Next-Gen Wireless-N Mini-card
BLUETOOTH AND WIRELESS USB: Built-in Wireless USB capability
BLUETOOTH AND WIRELESS USB: Dell Wireless 355 Bluetooth Internal (2.0+Enhanced Data Rate)
BATTERY OPTIONS: 85 WHr 9-cell Lithium Ion Primary Battery
SOUND OPTIONS: Integrated Sound Blaster Audigy HD Software Edition
FINGERPRINT SCANNER: Finger Print Reader XPS M1530
This is for a dell XPS M1530 Laptop that will cost about $3k (that includes everything like software and optional stuff). If you think of a good system I should look at (that runs Windows) then please post because I would like to look at them. $3k is about the top of the limit for me which I think will get a nice laptop.
Also, should I spend an extra $200 for a 7200 RPM hard drive or stick with the 5400? I wouldn't mind it but I also don't want to hear it across the room. (A solid state drive, though unreasonable now, would be cool to have though because the laptop would make such little noise!!!).
You can do better for that kind of budget. Try customizing one at ibuypower.com I did a comparable one to that dell for about $1000 less.
How about a 17'' macbook pro configured with the 2.6GHz C2D and 4GB of Ram and a LED 1920x1200 Display
Well with what i have said below he is a list between $2500 to $3000 - http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2030260032+4087&name=$2500+-+$3000 - But they all have crap specs!!! I would say a mac or one of the ones i mentioned above
cohen said:
One of these
Thanks.
Actually, I'd be ok with spending up to $3k on a laptop.
WOW!!! That changes things!
Could do
Personally I think it would be a wiser choice to build from HP.
Well depends on what OS you want... Mac or Vista?
Thanks, good to look around for price comparison. I'm personally not a huge fan of macs but I can understand why some prefer them over windows. I guess it's just what you're used to.
