DeltaDart1
I'm sure I posted this before but I did a search and can't find it. Right now I have 512 PC4200 DDR2 RAM. I would at the very least like to double the memory. The MB is a FoxConn 6100 M2MA-RS2H and it's a AMD Sempron 2800+AM2. My system has 4 memory slots(2 yellow-2 blue-by the way does that make a difference?) I have 1 512 stick installed in one yellow slot. To double my memory would it be best to add another 512 stick? If so does it make any difference which slot-yellow or blue-that I install it? What exactly is the type of memory stick that I should buy? The memory stick that is installed is a Kingston.Thanks for your help!
