8800GTX or SLI 8800GTS
SLi will perform better.
The only disadvantage is that you can't run more than 1 monitor if you run SLi.
that wont be a problem because a 24" is plenty
i ask this is because i know adding a 2nd card wont double the performance. it's that law of diminishing returns. so at lower resolutions (using smaller monitors), would it make such a big difference?
i would go with the single 8800gtx the difference wont be very noticeable, plus you'll have an open slot for another 8800gtx in the future
