Will PSU handle new components?
Get a better PSU.
By the way, if you plan to get new CPU + Mobo + RAM, You'd better go for intel, they are better set up than AMD currently.
thanks, do you think the PSU will hold off a week or so till my next check?
And if you'll see my thread on my CPU selection in the CPU section fo the forum that'd be great.
Get a better PSU.
Agree
Yes, it will last but when you get the new video card get a New PSU at the same time.
That PS is Junk. I wouldn't use it for a minute.
Well that is your own opnion.
already got the card... anyone suggest a good cheap psu? here are my prospective specs:
E7200 or E6300 < will buy
Foxconn M7PMX-S or Gigabyte 965P-S3 rev 3.3 < will buy
2gb ddr 800 or 1066 (not sure yet, 2gb tho) < will buy
HD3870 512mb <have
1x dvd burner, 1x dvd rom <have
1xsata, 1x ide hdd's <have
2x 12cm case fans. <have
