If you added in all your fans, drives, lights, etc, then it should be fairly accurate. For $2 you can actually get the "pro" version which shows you the required amperage as well.Dazzer, What hardware do you mean? Because I'm looking at getting a Q6600, EVGA 750i FTW and another GTS to run SLI...
Geoff, That calculator says I'd need 471watts, That's with a Q6600 at 3.4Ghz with a 1.45vCore.
[-0MEGA-];994322 said:However, even if it only requires 471W, you don't want your 520W PSU to bebe under almost 100% load all the time, and it will fail much sooner.
the thing is, how many 400W PSU's come with enough PCI-E connectors for say, dual 8800GTX's? they might have the amperage for it, but the connectors just arent there.[-0MEGA-];994322 said:If you added in all your fans, drives, lights, etc, then it should be fairly accurate. For $2 you can actually get the "pro" version which shows you the required amperage as well.
I believe most people overestimate what they need in terms of power, some people say you need at least 750W for an SLI setup, when in reality it only needs 450-500W. BTW did you set the processor/system to 100% load?
I'm using a HX520, and with a Q6600 at 3.51GHz, 8800GTS 512 clocked at 792/1890/2106 (I'd say throw in an extra 25W for a GTX), 3 HDs, and 4DIMMS. During Crysis I'm pulling about 280W-300W FROM THE wall. Factor in 80% efficiency and that's about 230-240W in the system. The CPU and GPU both fully loaded, about 270W DC. My 12V rail is rock solid, but with a single card setup it's very hard to stress the HX520. But I wouldn't be surprised if the HX520 could run a GTX in a SLI given the power draw I see in my system. I definitely have the headroom for an extra GTS, but sadly - my P35 doesn't support SLI.
