You can see exactly how much RAM you have by going to your Control Panel and Clicking "System". Right there under the "General" tab, you should see your CPU and RAM Listed. You should post those here for futher Diagnostics. It would also help if we knew what we were dealing with, so if you could post your Brand and Model of computer, that would help as well. It's possible that you may not be able to upgrade your RAM much further. Computers have a Useful life of around 3 years if you're not a Power User. Sometimes you can get away with 5 years, but i don't recommend it. What's your Operating System? (I should have asked this First)
** I hope I'm using this quoting thing right!
Windows XP Home Edition
Version 2002, Service Pack 2
Compaq Presario (geek friend calls it comCRAP) ...True??
AMD Sempron Processor 3500+
1.79 GHz,
448 MB RAM
Physical Address Extension (what is that?)
If it was refering to Services, i think you were on the wrong tab. There IS a services tab, but that could make your computer unbootable if you disable all of those. make sure you're only dealing with the STARTUP tab.
** I went back to see where I found that. Went to start, run, msconfig, went to STARTUP tab and the ONLY thing checked off was ctfmon.
"CA" is NOT checked off...isn't that my security? Don't I want it running?
Anyway, at the bottom I just hit OK without changing anything. I didn't check or uncheck anything and I got that same message:
..."An access Denied error was returned while attempting to change a service. You may need to logon using an Admin account to make the specified changes" WHAT does that mean?
The only sound i could diagnose from here reliably would be your post Beep Codes. If your machine is healthy and there are no conflicts during post, you should hear one distinct Beep.
**What is a beep code?
No, you can't have CA and AVG at the same time.
**Is CA good ?
My hard drive space isn't an issue I don't think...
I have a C drive: 142 capacity, used only 14.8 GB
My 2nd is Drive D: 6.95 GB, Used 5.77
make sure you ground yourself to the Chasis of the machine. They make Wrist Straps, or you can just Touch it. If you've got SDRAM or DDR (I Hope you do). then all you have to do is open the case and look for the Memory slots. You've done this once before,
**First of all...All you had to say was GROUND yourself & that was enough.
Yeah, been there, done that & fried the motherboard
SO it appears that I'll get someone to help me. Anyone know of reputable people in Cincinnati?
The only way to tell exactly what Kind of RAM your machine takes and how much of it, is by looking on the Manufacturers Website. That's a Good Reason to post your System Brand and Model Number.
**Compaq Presario, and I think the model # is HP375052-001 ??
Is this an HP machine? Same as Compaq?
The External Hard Drive Solution would be Easier. With CDs, you will accumulate quite a collection in no time. A Hard Drive will hold alot more. That way you'll be able to keep them all in one place. Some Photo Applications are VERY CPU and RAM intensive.
**Sounds like I really need to get one, but I have NO IDEA of what I need.
Will this completely back up all my programs?
Can I set it up to backup daily or what?
I don't actually DO much with the photos. I never print them off, but I do edit them. Don't know HOW I got 3 different photo programs, but I prefer to use PAINT. NOW for some reason, (started a while ago) if I just dbl click it opens my photos with MS Photo Editor. I have to right click, open with, then Paint. I also have Windows Pic & Fax Viewer. Can I delete the 2 I don't use?
Any reason that you know of to keep either?
BTW my pictures are opening up a LOT faster since I did that disabling thing.
AGAIN, thanks so much & God willing the hard drive holds out, I'll be back
Bev
