$1300 build. Long read. In depth help appreciated. Help with priceing
webwierdo
APPROXIMATE PURCHASE DATE: 1-2 weeks
BUDGET RANGE: $1200-$1350 Before Rebates Including Shipping
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Internet, Gaming, Movies
PARTS NOT REQUIRED: Need Everything
PREFERRED WEBSITE(S) FOR PARTS: Newegg
COUNTRY OF ORIGIN: AZ, USA
PARTS PREFERENCES: See comments below on each item but particular reference to the PSU
OVERCLOCKING: Some, but very basic.
SLI OR CROSSFIRE: Yes
MONITOR RESOLUTION: 1920x1080
Sorry, this will be very long. For those that read the whole thing, I thank you very much.
I know pretty much what I'm aiming for, but I would like some help getting it cheaper through the use of combo discounts on Newegg and items with free shipping. Some of the parts I'm set on. Others I don't really have any preference. The main goal therefore is getting it cheap as possible while maintaining part quality. I would also appreciate anyone pointing out incompatibilities or anything else that seems helpful. Below is the build I am thinking of currently but I found one outstanding problem.
MoBo: $179.99 ASUS P7P55D EVO LGA 1156
Not really attached to this board but it had decent phase, 12+2, and PCIe switching to 8x/8x(requirement) when two cards are present. I'm not using crossfire right now, but I plan to have the computer for a long time so when it starts being slow I can throw in another card to make it last a little longer. USB 3.0 and SATA 6 Gb/s would be nice but its not really important to me. I don't want a board that routes it through the PCIe lanes because using crossfire makes it useless.
OS: $99.99 Microsoft Windows 7 Home Premium 64-bit OEM
Nothing to really say about this.
Case: COMBO #1 = $129.98 COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case
This is a combo with PSU. Together they total $129.98. I don't really care much about the case. In general I don't like LED's or see through side panels but if it is a big enough difference in price I'll put up with them. My only real concerns are enough fans and fitting the GPU's in.
PSU: COMBO #1 = $129.98 OCZ ModXStream Pro OCZ700MXSP 700W ATX12V V2.2 / EPS12V
This is a combo with the Case. I hear mixed things about OCZ. Some say its crap, others swear by it. I'm not sure if 700W is enough. Keep in mind that eventually it will power 2 GPU's, 4 sticks of RAM, more fans, possibly a wireless card. This piece also has the only major flaw I've found(so far). The way I'm currently building my PC, I will eventually have 2 Radeon HD 5830's(though this isn't certain) which would require 4x6-pin connectors. This one only has 2 so when I go to add another GPU, I would have to replace the power supply as well. If possible, I would like to avoid this and fix the problem right now. I've been told about molex to 6-pin adapters. The power is split between 2x12v rails. I don't know if using the adapter would overload one of the rails. To be honest I'm not sure how this part really works. The best idea would be to just get a PSU with 4x6-pin but that breaks up my combo deals, and I've tried to rearrange them but the price goes up dramatically.
GPU: COMBO #2 = $419.98 XFX HD-583X-ZNFV Radeon HD 5830 1GB 256-bit
This is a combo with the CPU. Together they total 419.98. I'm not tied to XFX but I'm certain about wanting a Radeon. Realistically, I would settle for a Radeon HD 5770. After all 2x 5770 in crossfire can handle anything thrown at it. (At least for now.) I bumped it up from a 5770 to a 5830 because I knocked the CPU down a step and the combos came out so it fit nicely price wise. Keep in mind that if I did go with the 5770 (which I'm perfectly willing to do) I would no longer need 4x6-pin connectors as one 5700 only requires 1x6-pin whereas the 5830 needs 2x6-pin.
CPU: COMBO #2 = $419.98 Intel Core i5-750 Lynnfield 2.66GHz LGA 1156
This is a combo with the GPU. This is the minimum I am willing to go on a processor. If the combos work out for a nice price, I wouldn't mind an i7-860. I hear the only difference between the two is hyperthreading. It would be nice but I don't use many applications where 8 virtual cores are any better than 4 cores. In general I would like to keep it at an i5-750 and use the extra money on the GPU but again not rock solid on this point.
Memory: $110.99 Crucial Ballistix 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
I would prefer Crucial, not a requirement. I have a few questions about RAM and timings. I understand it is possible to overclock them to 7-7-7-20. Does this require much expertise or other equipment? Would it be much easier to just go with DDR3 1333 at those timings. Keep in mind that an i5-750 has to be overclocked to work with DDR3 1600. It normally maxes out at DDR3 1333. There were a lot of combo possibilities with memory but most of them were DDR16000 at 9-9-9-24. How much of a difference would this make.
HDD: $99.99 Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s
Could go with a smaller drive to fit a combo deal, but 500GB is probably the smallest. I read that 1TB drives can be faster than smaller drives because of data density. That would be nice but not very important. I doubt my HDD would end up being the bottleneck.
Monitor: $169.99 Hanns·G HH-231HPB Black 23" 5ms HDMI Widescreen
This happens to be on sale at the moment for the same price as the 22inch LCD I was looking at before. I haven't heard of Hanns·G, but the new egg reviews looked decent enough. If there is a big enough price difference between a 22inch and a 21.5inch or 20inch. I could settle but I would really like the 22inch.
DVD/CD: $24.99 Sony Optiarc DVD Burner with LightScribe Black SATA Model
LightScribe is a requirement. I burn lots of disks and hate the way marker looks on them. I used to print labels but it was such a hassle and I'm tired of buying there stupid paper. Other than LightScribe, I chose this because it looked decent quality and was cheap.
Speakers: $27.99 Logitech LS21 7 Watts RMS (FTC) 2.1 Stereo Speaker System
Not at all an audiophile. I got the one with the subwoofer because the speakers I have now(are breaking) has one. I don't know if I could tell the difference between one that does and one that doesn't though. It didn't seem to cost much more with it so I threw it in.
Card Reader: $14.99 Rosewill RCR-IC001 40-in-1 USB 2.0 3.5" Internal Card Reader
Decent quality. Cheap
Keyboard/Mouse $16.99 Logitech 967973-0403 Black PS/2 Standard Deluxe 250 Desktop
Subtotal $1,295.87
Shipping $ 17.72
_________________
Total $1313.59
For those of you still with me, thank you very much. I hope the read wasn't to horrible. Again I appreciate any comments on part choices but mainly I'm concerned with optimizing the price through combo deals and free shipping without losing quality. My main problem right now is the PSU incompatibility. If someone puts a lot of effort into this, and saves me a decent amount of money, I'm certainly willing to make a small donation($5-$15) through paypal. I not promising anything. I'm not paying anyone to work for me. I do however appreciate hard work and believe it should be rewarded. Once more, thanks for reading this monstrosity. I was hoping to cover all the bases and clearly get my point across. I'm so glad there are great people here who are willing to lend a helping hand.
daisymtc
bomberboysk
tweaktown review on Crossfire on 5830
Load at 494W
http://www.tweaktown.com/reviews/3170/sapphire_radeon_hd_5830_video_card_in_crossfire/index14.html
So, PSU with 80% efficiency => 474/80% = 593W. 700W could hold Crossfire 5830
However, to stay away from hassle, I recommend you get CORSAIR CMPSU-750TX/ Antec TruePower New TP-750.
Power supplies don't work like that,80% effeciency means that the unit will draw ~840W from the wall, 700W is the max continuous output, not max input. However, i would suggest one of these power supplies, excellent units at a very good price:
http://www.directron.com/s75qbb.html
GPU - OEM 5850:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5766668&CatId=3669
If you use bing cashback on tiger direct that card is just under $240.
I'd recommend this motherboard, cheaper with similar features barring usb 3.0/sata 6.0gb/s(sata 6.0 not really useful unless you are running an ssd anyhow):
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186176
The rc690 is one of my favorite cases,so no arguments there, but you can get it or another coolermaster case recertified from here for cheaper(recertified, but you save a good amount of money):
http://cmstore.coolermaster-usa.com/product_info.php?cPath=18_37_19&products_id=109
http://cmstore.coolermaster-usa.com/product_info.php?cPath=18_37_19&products_id=107
http://cmstore.coolermaster-usa.com/product_info.php?cPath=18_37_19&products_id=503
With the money you save between case, psu, and mobo, you can get a 5850+corsair memory:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.361500
Display: I'd recommend this asus display, better overall display with better warranty, but 21.5". Its a bit smaller than the 23", however due to it being smaller, dot pitch will also be lower resulting in a "sharper" image:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236053
HDD: Can save $20 going with a 7200.12, just as fast if not a bit faster than the caviar black as well:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148433
ODD: I cant argue with that drive, its one of my favorites due to having an NEC chipset. However, if you have never used lightscribe before, you will soon realize it is nothing but a novelty, the media costs far more, it takes nearly half an hour to "burn" a label, and its only greyscale.
Speakers: The LS21 are horrible, at bare minimum i'd recommend something like these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16836150040
http://www.newegg.com/Product/Product.aspx?Item=N82E16836113025
If you want a card reader, i'd recommend this over the rosewill:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820609298
CPU: I5 750, no combos:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215&cm_re=i5_750-_-19-115-215-_-Product
or, if you have a microcenter close, you can get the i7 860 for same price newegg wants for an i5 750:
http://www.microcenter.com/single_product_results.phtml?product_id=0317378
Gabe63
If you can save enough to get a 5850, or just get a 5850, you will be happy in the long run. Good research and info above.
