Looking to custom build a new PC. Really don't have a budget but I'm trying not to go overboard. Would like to have the capability of making the computer run things near max for the next 4 years or so. Would also like to run at least 2 monitors well, maybe even 3.
Mother Board - Asus P8Z68 Pro (Intel Z68 ATX)
- As far as i've read the Z68 is the best option currently?
CPU - Intel Core i7 2600k 3.4GHz Quad Core 95w
- Seems like this is generally agreed upon as the best option.
Ram - Appears 8 is enough, but wouldn't be afraid to spend a little extra to go above an beyond that. Is there such thing as to much?
Video Card - (2) ATI Radeon HD 6950 2GB
- From what i've read 2 of these gives you the option to run basically everything full blast plus gives the option for 3D and can run 3 monitors at 1080. Yet there not terribly expensive.
Sound Card - Creative Labs Soundblaster X-FI Titanium
- Appears this is the class of the field? Are there more than one version of this card?
CPU Cooler - Corsair CWCH50-1 Hydro H50 CPU Liquid Cooler
- Will this be enough? Haven't done much research into this yet
Hard Drive - Assuming for the money i might as well get at least 1TB if not 2?
Optical Drive - Debating on whether I need the Blu Ray or not.
Power Supply - Suggestions? Haven't researched it to much yet.
I'm fairly new to this side of stuff but trying to learn. Have had the same custom built PC since early 07 an its just now starting to slow down. Would try an upgrade it but i truly have no clue whats inside of it and don't have the documentation from it...
Thanks in advance for any help
