[-0MEGA-];473722 said:20 Pin is used on the older motherboards without PCI-E slots, such as socket 478, 754, as well as a few 939's and LGA775's.
24 Pin is used on new motherboards with PCI-E video slots, mainly 939, AM2, and LGA775.
20+/-4 Pin is the best of both, meaning that you can disconnect the 4 pins if you want to use it on a 20 Pin motherboard, or leave it on for use on a 24 Pin motherboard.
I was hoping to get something like this: http://www.newegg.com/Product/Product.asp?Item=N82E16817153023
But after what I just said in my previous post - is the output voltage and amps not enough...?
[-0MEGA-];473738 said:That wouldn't be good for the money.
You should look for a power supply with dual +12V rails, since they generally can provide more power.
Have a look at this one:
http://www.newegg.com/Product/Product.asp?Item=N82E16817174023
I use that one in my rig.
[-0MEGA-];473738 said:Have a look at this one:
LOL! I was just about to suggest that one.
I too use it in my rig.
Nice!
Can't wait to get all this new crap I just ordered - new sound card (x-fi), new video card (7800GS), and now a new power supply... Should be getting it all by Wednesday.
Thanks again you guys!
Adam
Just wanted to pop in real quick and thank you all again. Got all my stuff installed and it's running like a CHAMP!
