I have $330 to spend exactly to buy a graphics card although, I might need to update my amd 965 processor as well. The two cards i'm looking at is r9 290 and r9 290x which is better and can anyone suggest a better deal or card? Please explain in as much detail as you can. I'm not very good with computers
r9 290
http://www.amazon.com/Sapphire-VAPOR-X-PCI-Express-Graphics-11227-04-40G/dp/B00JJJW4Z2
r9 290x
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202145&cm_re=r9_290x-_-14-202-145-_-Product
r9 290
r9 290x
