4pin PWM to 3pin fan adapter
Discussion in 'Computer Cases, Power Supplies and Cooling' started by atthedouble2, Jan 9, 2010.
  1. atthedouble2
    atthedouble2 New Member
    60
  2. Matthew1990
    Matthew1990 New Member
    1,082
  3. StrangleHold
    StrangleHold Moderator Staff Member
    19,543
    You talking about hooking a 3 pin CPU fan to a 4 pin motherboard CPU fan connector? If so using a 4 pin adaptor is a waste of time. The CPU only has 3 wires regardless if you use a 4 pin adaptor or not. Motherboards 4 pin CPU headers are keyed so you can plug the 3 pin into it.
  4. atthedouble2
    60
    No. The CPU fan has 4wires (so it's pwm), but the connection on my fan controller is only 3 pin. So I need an adapter for it.
  5. atthedouble2
    60
  6. Matthew1990
    1,082
    Why is that? I think it would work.
  7. StrangleHold
    19,543
    It has a molex on it. He needs a 4 pin PWM to 3 pin adaptor.
  8. Matthew1990
    1,082
    I thought 4 pin was molex, nevermind.
  9. atthedouble2
    60
    no it's not, thank for your help though
  10. StrangleHold
    19,543
  11. atthedouble2
    60
  12. atthedouble2
    60
    AH no! I cant use that site! the shipping is like $15! for just a cable! omg!
  13. spynoodle
    spynoodle Active Member
    1,853
    The molex one listed earlier would still work for you though, right? It's not like you don't have an extra molex connector open. Unless, though, you want to control fan speed, in which case you would need the other kind of adapter.
  14. Stoic Sentinel
    Stoic Sentinel New Member
    1,793
    No, he doesn't want to power the fan. He wants to hook it up to his fan controller that only accepts 3-pin plugs.
  15. spynoodle
    1,853
    Oh, I see now. Just try to do some searches on ebay. You'll find something eventually.
  16. Aastii
    Aastii VIP Member
    13,291
    It isn't exactly what you asked for, but does the job fine:
    http://www.scan.co.uk/Products/Akas...nnectoer-for-RPM-feedback-for-the-motherboard
    You plug it into a molex adapter from the power supply, plug one into your motherboard (the only female one :p) for fan control and then you have 3 of the 4 pin connectors that you need, so enough to plug into your motherboard and keep a spare if you have to unplug a currently being used fan.
    Scan are in UK too, so shipping should be cheap (they send by courier though, so don't quote me). If you are in north west UK, they are based in Bolton, so you may find it cheaper to go pick it up yourself (on the retail park opposite Reebok Stadium)
Share This Page
