Not much really. A half meter, 12 cm diameter pipe will have a friction pressure drop of less than 0.5 Pa (Pascal) given a 40 CFM. Considering that normal fan will have about a 20 to 30 Pa deltaP, and that 50 cm is probably longer than anyone would need, it doesn't have much affect. Changing the diameter, on the other hand, will affect the Reynolds number which will then affect the friction factor, but I think you would have to have low flow rate with large diamters for that to make much difference.Yeti, how would this model be effected by increasing pipe length??
It will depend a lot on the ability of the fan (pressure rise & CFM). Most likely, though, the duct friction won't make much difference. For example, even at 100 CFM (higher CFM = higher velocities = higher friciton loss) it would take about a 10 m pipe to decrease the performance of 1 fan by 1/2.I was more thinkink of piping the air in from outside. I have a old fan vent near my machine. Pipelength probably 1m required.
Not trying to get a frictionless solution, just making sure the fan can handle it.so no need for a perferct frictionless solution.
True, but if you want to design something it helps to know before you build it if it will cool right .if it cool right its already good
this ranks as one of the more advanced topics discussed here, and is for the most part way above my head (and yours). But that doesn't mean we have to stiffle the thread.dont start this again... this is just to get a bit air into the case,.. nothing industrial. so no need for a perferct frictionless solution.
if it cool right its already good.
