ok, it seems like it could do what i want it to, but i really have no clue where to start, shall i enter this into a query criteria box, or on the form itself ina new field box...??
Can you give a few hitns as to what the code would look like, i have two fields, obviously. One is 'lesson_type' and one is 'cost' i want the cost to change depending on what is selected in the lesson type box.
LESSON TYPE ----------- COST
Beginner 1hour ----------- 15
Beginner 2hour ----------- 29
Beginner 3hour ----------- 42
Test Retake 1hour -------- 13
Test Retake 2hour -------- 25
Test Retake 3hour ---------36
Disqualified Retake 1hour -- 25
Disqualified Retake 2hour -- 49
Disqualified Retake 3hour -- 72
Advanced 1hour ---------- 10
Advanced 2hour ---------- 19
Advanced 3hour ---------- 27
Is ti possible to do that, change the cost correpsonding to what one is entered in lesson_type...??? And where do i put it??? What do i do with it??
Thanks, dragon2309
