Okedokey
Well-Known Member
Not withstanding anything that has already been said.. im 99% confident that the following process will solve it.
- Download and install the latest chipset drivers https://www.asus.com/Motherboards/SABERTOOTH_990FX_R20/#support
- Restart
- Download and install the latest SATA drivers https://www.asus.com/Motherboards/SABERTOOTH_990FX_R20/#support
- Restart
- Download and extract to a FAT32 formatted USB stick (with nothing else on it) the latest motherboard BIOS https://www.asus.com/Motherboards/SABERTOOTH_990FX_R20/#support
- Restart
- Enter the bios and use the update BIOS utility
- Follow prompts
- Shutdown
- Remove all non essential hardware, that includes, non windows HDD, USB etc
- Reset the CMOS
- Start PC and enter BIOS
- Restore default BIOS settings (usually F5 then F10).
- Restart
- Re-enter bios, set the secondary boot option as your SSD and make sure its AHCI.
- Set the first boot option as DVD
- F10 and save and restart
- With Windows DVD installed, enter Windows installation
- Delete ALL partitions on windows SSD (assuming you only have windows on it and all files are backed up)
- Without creating any new partitions, click next to install windows
- Once Windows is installed, repeat steps 1 and 2.
- Update Windows.
