This may be hopeless for my system, I had a drunk person throw up all over inside my computer tower. It was next to my bed and the side pannel was off of it, and this girl rolled over to throw up and about half of it went inside my tower. Luckily, the computer was turned off. Next morning, I took every component out and washed the acidy tacobell off of it. I'm not sure if using water was the best idea, but I couldn't think of anything else. I let all the components sit in the sun for a while, then back inside for the night. About 24 hours after it was washed it was re-assembled. I hit the power button, the fan turned about a half turn and stopped. So I figured it was screwed. But, about 2 hours later, I came back from Chicago, and the computer was sitting there running. But, no image on the screen. I figured ok maybe I had the IDE cables backwords or something. So I held down the power button again, and it wouldn't turn off. I unplugged it, let it power down, pluged it back in, and now it wont turn on again. I tested the power button with my DMM and it works fine, so it's not the switch. Any ideas on what would cause this?? And by the way, no puked made it in the power supply, I didn't wash it except for the wires. Thanks.
