linkin
Okay, i got my new E6300 CPU up and running today. but now i cant run all 4gb of my memory in dual channel. i either get no video, or bad post with some lines across the screen. i can, however, run all 4gb in single channel mode, or less than 4gb in dual channel. I can even run 3 random sticks together, boots and posts fine. but with 4gb set to run in dual channel it has issues. this happened with my E4500 as well, but i finally managed to get everything to boot properly, dual channel and all. i did not remove the DIMMs when i changed the CPU. I did however unplug the power.
Nothing is overclocked, yet.
I have the bios revision 1403 for my board, latest one as far as i know.
I just had a BSOD with a memory dump, something along the lines of BAD_POOL_HEADER.
I just decided to run 2gb for now
The memory i am using is 4x 1GB Corsair XMS2 800mhz sticks. 2 sticks are ver2.7, the other 2 are ver5.2 (the 5.2 ones are the ones Aastii sent me
EDIT: checked Asus website, new 1404 bios is out. be back after flashing
According to this my memory is on the QVL:
http://dlsvr04.asus.com/pub/ASUS/mb/socket775/P5N-E SLI/P5N-E_SLI_QVL.pdf
(the corsair memory)
