Any way to lower CPU fan speed???
I have a ZALMAN 9500A cooling a Q6600 and its so loud...I have it down clocked right now so theres no reason it needs to be running so fast...Is there any way to slow it down??? I have looked all through the bios but cant find anything...Here is my motherboard......
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128357
I did as you said and downloaded & installed ASUS PC PROBE, as soon as I started it it started trowing warnings at me:
"There are some warnings: V core voltage
