Auto load problem
Rod Tibbs
For some peculiar reason my PC has started loading and running Real Player whenever I switch it on. I have tried removing it from the start menu but then get a warning that the start menu has been altered every time I switch on.
Can someone help me with this please? I just don't want Real Player to auto run every time I switch on. Help !!!
Thanks
Rod
PS I am running Windows XP
maybe this will help, go to start, run, type msconfig.exe, press enter, a window will pop up, go to startup tab, and untick anything with realplayer in it. that in theory should stop it. hope it helps
Thanks Cameldude. That seems to have done the trick and at the moment Real Player is minding its own business. Thanks lot.
Rod
