Sure you willWhatever you do has got to improve it, right.
Sometimes I think we get too technical, we should just reverse the vacuum, open the window and blow it out. Job done![]()
Yea, well I have no idea about all the alcohol percent, it's all just pretty numbers to me.
Yea, I mean, there is dust everywhere. But I don't really care, I mean there will be less dust after then there will be before so I come out on top anyway... right?![]()
Yea, whatever I do has got to improve it.
Probably. Usually I just take the components out and use the vacuum with the brush attachment (which makes it less staticy.. I think) and do it that way. But always gotta try new stuff.
Q-Tip, and actually i prefer coffee filters. Q-Tips are made of cotton, the cotton leaves strands, and cotton is a thermal insulator.
