Hello sorry if this is in the wrong category.
At the minute, apart from my laptop I have two computers.
Both 1gb ram
both asrock motherboards
both pretty much the same specs
one of them however loads and then after about 15 minutes it just turns itself off
its not the psu or the ram as ive replaced them in the other computer and the other one works fine
just wondered whether it'd be possible to take the cpu (both cpus are the same) from the good computer into the one thats broken to test whether it was the cpu causing the problem
apart from an antistatic wristband that i have, will i need any other kit to remove it. how easy will it be, it'll only be for a couple of hours whilst i see if it turns off, just to diagnose whether i need to buy a new cpu or motherboard!!
For information
cpu: amd athlon xp 3000+
motherboard: As Rock K7S41GX
It's only a basic pc for simple web browsing e.t.c.
thanks
Danny
Any advice appreciated
Both 1gb ram
For information
thanks
Danny
