Happy_Demon
A freind and I are building this computer, and I would like additional opinions to whether all of these things will work together. Rather high budget computer with primary intentions being: LAN Parties, Half Life 2, World of Warcraft, and word processing. What I have here is all I would be ordering and getting so if I am missing anything important and vital please tell me.
Do I need anything additional for LAN hookups? The place I play at has a LAN box or router or something so I just need to be able to hook it up. (P.S. Age of Empires II still rocks)
Much obliged for any concerns or suggestions, thanks. Here it is:
CASE:
Broadway com Black ATX Mid Tower Case With 500W PSU, Model "82-4HL-Black" -RETAIL
- Specifications -
Case Type: ATX Mid Tower
Color: Black
Material: Japanese SGCC Metal
Drive Bays: 5.25" x 4/0, 3.5" x 2/4 (external/internal)
Expansion Slots: 7
Front Ports: 2 x USB2.0, 2 x Audio, 1 x IEEE1394
Power Supply: 500W
Cooling System: 1 x 80mm front fan, 1 x 120mm rear fan, Air Guide/Air Dust with 80mm Fan on SidePanel
Motherboard Compatibility: ATX / MICRO-ATX
Dimensions: 8"W x 16"H x 18.5"D
Features: Front Panel Blue neon light Temp Control Disp., Temp. Disp (HDD, VGA, CPU & Timer)
Model#: 82-4HL-BLACK
Item#: N82E16811162027
$46.00
Link:
http://www.newegg.com/app/ViewProductDesc.asp?description=11-162-027&depa=1
CD DRIVE:
Aopen 16X Double Layer DVD+/- RW Black Burner, Model DUW1608, OEM
Model# 91.4ID37.004
Item # N82E16827140115
Specifications:
Write Speed: 2.4x DVD+R DL (Double Layer), 16x DVD+R, 4x DVD+RW, 8x DVD-R, 4x DVD-RW, 48x CD-R, 32x CD-RW
Read Speed: 48x CD-ROM, 16x DVD-ROM
Interface: ATAPI / E-IDE
Buffer: 2MB
OS Support: Windows XP/ 2000/ ME/ 98SE
Features: JustLink Buffer Underrun Errors Prevention Technology, Dynamic Damping System (DDS) to reduce vibration/noise, JustSpeed technology for adaptive writing speeds.
Packaging: OEM (see pictures for details)
$60.99
Link:
http://www.newegg.com/app/ViewProductDesc.asp?description=27-140-115&depa=1
HARD DRIVE:
Western Digital 80GB 7200RPM SATA Hard Drive, Model WD800JD, OEM Drive Only
- Specifications -
Capacity: 80GB
Average Seek Time: 8.9 ms
Buffer: 8MB
Rotational Speed: 7200 RPM
Interface: Serial ATA
Features: Not specified
Manufacturer Warranty: 3 years
Packaging: OEM Drive Only
Model#: WD800JD
Item#: N82E16822135106
$64.49
Link:
http://www.newegg.com/app/ViewProductDesc.asp?description=22-135-106&depa=1
KEYBOARD & MOUSE:
CODEGEN 2C-004-CAC9 Keyboard and Mouse Combo -RETAIL
- Specifications -
Interface: PS/2
Number Of Keys: 107 keys
Wireless Technology: N/A
Palm Rest: N/A
Design Style: Slim
Mouse included: Optical Wheel Mouse
Model#: 2C-004-CAC9
Item#: N82E16823185003
$10.50
Link:
http://www.newegg.com/app/ViewProductDesc.asp?description=23-185-003&depa=1
MEMORY:
OCZ Performance Series Dual Channel Kit 240-Pin 2GB(1GB x 2) DDR2 PC2-5400, Model OCZ26672048PFDC-K -RETAIL
Model# OCZ26672048PFDC-K
Item # N82E16820227011
Specifications:
Manufacturer: OCZ Technology
Speed: DDR2-667(PC2-5400)
Type: 240-Pin DDR2 SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 4-4-4-8
Support Voltage: 1.8V
Bandwidth: 5.4GB/s
Organization: two 128M x 64 -Bit
Special Features: 2.2V EVP
Warranty: Lifetime
$725.25
Link:
http://www.newegg.com/app/ViewProductDesc.asp?description=20-227-011&depa=1
MODEM:
AOpen 56K V.92 PCI Modem, Model FM56-SVV - Retail
Model# FM56-SVV
Item # N82E16825131005
Specifications:
Interface: PCI 2.2
Standards: V.92 and earlier ITU standards, G III
Chipset: Conexant CX11252-11 single chip HSFi V.92
DTE Rate: 115200 bps Maximum
Fax Speed: 14400 bps
$11.49
Link:
http://www.newegg.com/app/ViewProductDesc.asp?description=25-131-005&depa=0
MONITOR:
AllyStar M141-Black 14" LCD Monitor -RETAIL
- Specifications -
Panel Type: 14.1" TFT Active Matrix LCD
Native Resolution: XGA 1024 x 768
Pixel Pitch: 0.279(H) x 0.279(V) mm
Brightness: 150 cd/m2
Contrast Ratio: 250:1
Response Time: 50 ms (typ)
Input Connectors: D-sub 15 pin
Dimensions: 16" x 17.3" x 0.75"(W x H x D)
Manufacturer's Warranty: 1 Year
Dead Pixels Policy: Replacement or Refund for 8 or more DEAD PIXELS ONLY!
Model#: M141-Black
Item#: N82E16824178008
$175.99
Link:
http://www.newegg.com/app/ViewProductDesc.asp?description=24-178-008&depa=1
MOTHERBOARD:
Intel "BOXD925XCVLK" 925X Chipset Motherboard For Intel LGA 775 CPU -RETAIL
**This item is warranted through the product manufacturer only.
- Specifications -
Supported CPU: LGA775 Pentium 4(HT) Processors
Chipset: i925X + ICH6R
FSB: 800/533MHz
RAM: 4x DIMM for Dual Channel DDR2 400/533 (Intel PAT) Max 4GB
Slots: 1x PCI-Ex16, 2x PCI-Ex1, 4x PCI
Ports: 2x PS/2, 1xCOM, 1x LPT, 8x USB2.0(Rear 4), 3x 1394(Rear 1), 1x RJ45, 2x SPDIF Out, Audio Ports
IDE: 1x ATA 100 up to 2 Devices by ICH6R
SATA/RAID: 4x SATA by ICH6R with RAID 0/1
Onboard Audio: Intel High Definition Flexible 8-CH CODEC
Onboard LAN: Gigabit LAN
Onboard 1394: 3x 1394
Form Factor: ATX
Model#: BOXD925XCVLK
Item#: N82E16813121226
$189.75
Link:
http://www.newegg.com/app/ViewProductDesc.asp?description=13-121-226&depa=1
PROCESSOR:
Intel Pentium 4 560 3.60GHz LGA 775, 800MHz FSB, 1MB L2 Cache Processor w/ Hyper Threading Technology - Retail
(limit 5 per customer)
- Specifications -
Model: Intel Pentium 4 560 w/ Hyper Threading
Corerescott
Operating Frequency: 3.6GHz
FSB: 800MHz
Cache: L1: 16k+12k, L2: 1MB
Process: 90nm
Socket: LGA 775
Multimedia Instruction: MMX, SSE, SSE2, SSE3
Packaging: Retail (with Heatsink and Fan)
Model#: BX80547PG3600E
Item#: N82E16819116181
$450.00
Link:
http://www.newegg.com/app/ViewProductDesc.asp?description=19-116-181&depa=1
SOUND CARD:
Built into motherboard.
VIDEO CARD:
SAPPHIRE ATI RADEON X600 PRO Video Card, 256MB DDR, 128-Bit, DVI/TV-Out, PCI Express, Model "589L" -RETAIL Lite Box
Model# 589L
Item # N82E16814102419
Specifications:
Chipset/Core Speed: ATI Radeon X600 PRO/400MHz
Memory/Effective Speed: 256MB DDR/600MHz
BUS: PCI Express x16
Ports: VGA Out(15 Pin D-Sub) + TV-Out(S-Video) + DVI
Support 3D API: DirectX 9.0, OpenGL 1.5
Max Resolution@32bit Color: 2048X1536
Cable/Accessories: S-Video adaptor, Driver CD
Retail Lite Box (See pics for details)
$122.00
Link:
http://www.newegg.com/app/ViewProductDesc.asp?description=14-102-419&depa=1
Thanks again.
CASE:
- Specifications -
Color: Black
Expansion Slots: 7
Power Supply: 500W
$46.00
Link:
CD DRIVE:
Model# 91.4ID37.004
Specifications:
Buffer: 2MB
$60.99
Link:
HARD DRIVE:
- Specifications -
Capacity: 80GB
Buffer: 8MB
Model#: WD800JD
$64.49
Link:
KEYBOARD & MOUSE:
- Specifications -
Interface: PS/2
Palm Rest: N/A
Design Style: Slim
Model#: 2C-004-CAC9
$10.50
Link:
MEMORY:
Specifications:
Bandwidth: 5.4GB/s
Warranty: Lifetime
$725.25
Link:
MODEM:
Model# FM56-SVV
Specifications:
Interface: PCI 2.2
$11.49
Link:
MONITOR:
- Specifications -
Model#: M141-Black
$175.99
Link:
MOTHERBOARD:
- Specifications -
FSB: 800/533MHz
Form Factor: ATX
$189.75
Link:
PROCESSOR:
- Specifications -
Corerescott
FSB: 800MHz
Process: 90nm
Socket: LGA 775
$450.00
Link:
SOUND CARD:
VIDEO CARD:
Model# 589L
Specifications:
$122.00
Link:
Thanks again.
