Ryan Tegtmeier
There is a simple answer I presume but I am wondering if there is a simple way to know why I shouldn't use a single cable to connect the power to multiple storage sources. I was putting together my own build and it started smoking (yikes!) . I separated the cables into each storage device and it works fine now. Is there a simple way to tell what instances there are where I can use a single cable for both storage sources? I don't mind using separate cables; I just want to know why it started smoking. Thank you in advance.
