Can a Li-Ion Battery Replace a Ni-Mh Battery??
Discussion in 'Laptops, Tablets and Smartphones' started by SonMob, Jan 9, 2020.
  1. SonMob
    SonMob New Member
    2
    I have an old Inspiron 2200 with a almost dead Ni-Mh battery.
    Type P5413.
    Can I replace this with a Li-Ion Battery and will it work with the internal charging system???
    I have a lead on this one in ebay:
    .......... replace T5443,w5543 Li-ion 14.8v 5200mah/77wh
    OR, where can I get a used one that will last for a while.........
    Thanks.
  2. johnb35
    johnb35 Administrator Staff Member
    42,053
    Check ebay as well.
    https://www.ebay.com/c/1639311085?iid=160667132887
    Just make sure its has same voltage and amp ratings as original. Also, something about updating the bios to latest version when going from Nimh to LIon. Might want to contact Dell.
  3. strollin
    strollin Well-Known Member
    1,985
    Those 2 battery types have different recharging requirements and are NOT interchangeable.
    beers likes this.
  4. beers
    beers Moderator Staff Member
    8,462
    No as nimh and liion have different charging requirements.
  5. SonMob
    SonMob New Member
    2
    Thank You all,
    I will look for a stock replacement battery.
Share This Page
