WingedWombat
Ok, so here's my problem: I recently bought a case from PC Club, heres a link to where you can look at specs and pics
http://www.pcclub.com/product_detail.cfm?itemno=A1330510
I also bought some case fans, just normal 80x80x25mm led case fans (XG Extreme Gamer ACFA 4LED-XBG) to put in it. Unfortunately, this is my first time building a computer and I can not figure out how to install them. More specifically, the holes on the case are bigger than the screws that came with the fans, and the 2 front fan ports have a small cylinder coming up maybe 4 mm with some wires in sticking out which are labeled speaker, so there must be a speaker right there, but unfortunately this cylinder is right in the middle, blocking both from getting to there screw holes and I can't figure out how to put either of those fans in the right position (not to mention the fact that the fan grills that came with the fans won't fit on the fan if they're over the honeycomb because the drive bays are in the way). Also, I don't know anything about fans, are the holes generally unthreaded when the fans come (it looks like my screws are self-threading, but I'm not totally sure)? Any help would be greatly appreciated.
