When you got your new card did everything work before changing out the power supply? In other words did you try the card before changing the power supply?
Out of curiosity, do you know for sure that the CPU is seated well? Did you pull the tab up, insert it, and lock it down? I've seen more than one person just shove the cpu into the socket without using the lock mechanism, which is a very good way to damage things.
I won't be asking them to ship a motherboard here.. Ill just go to a regular computer store and ask if they could order the motherboard..
From those two ASUS up there.. Which one is the best?
can anyone help me out?
I've been looking for some motherboards since mine has died.. But i keep running into problems:
8 pin cable (not available on my psu)
bigger format (mine is 9.6" x 9.6")
doesn't support AMD Athlon 64 x2 4400+ cpu..
So.. could someone find me one or two motherboards that are compatible with my last one.. Would be very grateful!!
The details again:
DDR2 Ram Memory
4 pin + 24 pin connection
9.6" x 9.6" size
AMD Athlon 64 x2 4400+ CPU
CrossifireX or OC isn't important.. But if available it's even better..
Budget is around 70€ which is around 75/80$..
Thanks in advance..
Thank you so much!!
Thank you so much!!
