Compaq Evo N110 - CD-ROM Problem
m129
My laptop does NOT detect my new DVD/CD-RW combo drive at all, neither does it detect any other optical drive, other than the original CD-ROM which has its tray removed. A BIOS update didn't cure it either.
Any help appreciated. Thanks. :confused:
Whoops
I had the same problem with mine, the weird part was my drive was a toshiba, but anyways the store where I got mine gave me a warranty so I just took it back and told them to replace it, you should probably do the same.
Jerkstore
does the optical drive work properly?
if you can't boot up from CD then your drive is defective or not copatable with your notebook
