Forest Gospel
Living in california is killing me right now. Newegg charges tax to california residents.
Not true. Crossfire is available on a variety of chipsets for both AMD and Intel CPUs - and there's no catch like worse performance when pairing up Intel on a Xfire mobo or anything like that. As for SLIing 9600GTs, I doubt dual cards here would give a significant performance boost and ain't a good choice considering that there are single-card solutions that beat 2x9600GTs in terms of both performance/price ratio and absolute performance. For medium-weight gaming where a single 9600GT would suffice, it's a great choice but I really don't think it's a wise move to go and SLI two of them. I'm still recommending the 4850.And Crossfire mobos are only for AMD CPU's
For gaming, Vista is the way to go (DX 10). In addition to that, XP's losing supports, getting old blah blah... and most of the problems I've had with vista I have had because thing is blppdy slow but I was running it on a AUD$400 machine, with his hardware Vista should run well. Chances are he ain't going to play games like Duke Nukem, DooM and Terminal Velocity, so software compatibility ain't much of an issue here.Vista is the infernal spawn of Satan. Even the almighty Compatibility Modes are powerless to help with most programs. Stick with XP Pro.
Just like shortman said... performance-wise, memory speed is of minor importance, the difference will at most be a few FPS. As for the CPU, he said that he wants a quad...For gaming purposes, faster-clocked dual-core chips are much better than slower-clocked quad-core chips, and faster memory is better than more memory. An E8400 and 1 GB of DDR2-1066 will serve you well.
430W? Easily? I wouldn't think so. I really don't know a lot about PSUs and such, but 430W sounds a little low...A 600W PSU is obscene unless you're using four graphics cards and a 150W CPU. You can easily cut down to a 430W PSU if it's 80+ certified.
No it's not. Sure they're not bad, but it sounds as if you were saying that they're better than everything else... I wouldn't trust them, simply because I'm not familiar with their products, never heard a thing of them.When it comes to 7200RPM hard drives, Excelstor is the company to buy from.
Wow that PSU is really good. For $970 I would say you scored yourself a deal. Now the only problem is putting it together and making sure nothing arrived DOA. Haha.
The dual core he was going to get was 2.5GHz. The quad core is 2.4GHz.
Since some games now utilize two cores
Now he will have two extra cores to run system processes that would otherwise run on the cores that would also be running the games.
Losing two cores is not worth 0.2GHz.
And faster RAM is not always better than more RAM.
And you could use that money to buy a better card which would give much better performance.
600W is not obscene. An 8600GT requires a 400W PSU, and that video card is junk. 450W is recommended for an 4850 and it's always good to have extra.
In terms of reliability, they are easily on par with WD or Seagate. The only difference is that Jupiters give you more for the money. They're like the "next Corsair" or "next Asus" of hard drives.
