Hi, i just got a computer from my aunt that she got from a friend. It has a water cooling system to the cpu. I cannot tell if he pump is sending water throught the pipes. When i turn on it does not make any noise. I checked bios for cpu temp after about a min and was 57 degrees celcius. I do not know what to do to even tell if the pump is working. If you know what i can do to fix it would be great.
thanks
thanks
