Computer will not post,please help
Lane
I am having trouble with my computer not posting, sometimes it will but now it seems to stop here:
PHOENIX-AWARDBIOS V6.00PG
(6A61ITT2) RELEASE NUMBER 691NOP20
NVIDIA BIOS VERSION:2.053.60
MAIN PROCESSOR: INTEL (R) CORE (TM) 2CPU 2.40GHZ (266X9.0)
MEMORY TESTING: 2096128K OK
CPU BRAND NAME: INTEL (R) CORE (TM) 6600 @ 2.40 GHZ
C1E BIOS SUPPORTED
EM64T CPU
and will not go any further as I keep reseting.
Here are my specs:
Antec Nine Hundred Black Steel ATX Mid Tower
NVIDIA nForce 680i SLI ATX Intel Motherboard
Intel Core 2 Duo E6600 Conroe 2.4GHz
BFG Tech BFGR88768GTXE GeForce 8800GTX 768MB
CORSAIR XMS2 2GB 800
WD1500ADFD 150GB 10,000 RPM
PC Power & Cooling Silencer 610
SAMSUNG 940BF Black 19" 2ms
Logitech G5 Laser
LITE-ON Black Burner
I have cleard cmos but didn't seem to help, I have had this computer for about a year now.
Could it be the battery on the motherboard?
After powering it down completely and it began to post further I was able to get into setup and change the multiplyer to 7x but now it is froze again.
Also I got a check sum error
Lane
Finally got it to load windows but after a brief minute it flashed a blue screen with white text and then proceeded to reboot then froze again while posting. How irritating!
dannaswolcott
check your heat sink and fan it might be clogged causing your computer to freeze. Did you build the computer? Whats its brand?
dannaswolcott
If its not the heat sink or the fan, your motherboard, cpu, or memory may be going bad. But it sounds like a heat issue to me.
Lane
Yes I built it my self please see sig for equipment also I will atach my config.
It has started normally for 2 days now and has not shut off, I can't explain it.
Please see atached.
  • cpuz.zip
