Connection problems.
Dsk954
Im just kinda shooting in the air here but do you have a dynamic IP that isnt set up correctly? When I read your post it seems like your IP is being switched by the service provider (or your wireless router switches it for your LAN to keep it secure?) and you do not have the settings hooked up correctly. So your connection looks like this? Cable modem hooked up to a router which is hooked up to a wireless access point? When you connect your ethernet cable, do you connect it straight up to the cable modem or do you hook it up to your router? If you hook it up to your router and everything works, I would suggest seeing if your Wireless point is set to dynamically change your IP?
Sorry, I have a very basic networking education, I read the CCNA book but still im clueless :confused:
