By wiring up two power sources in seriesif so how do i make the speed higher?..
how?Praetor said:By wiring up two power sources in series![]()
oic but the thing i dont get is that the other people i compare with have the same CPU(x2 4200) and use the stock HSF, same as me, but i get higher temps while they are way lower. thats y i want to see/test if the speed of the fan is my problem. b/c it seems low to me when i hear of all these high temps. like you 2100rpm mine is like 900rpm-1000rpm which is way lower.The_Other_One said:Yeah... He was probably suggesting taking a 12v line and a 5v line and combining them. However, the fan would probably burn out seeing as they usally aren't meant to take more than 12v
Not all fans need speed. Many higher performace fans(particually larger ones) can move more air at lower speeds. My CPU fan runs at about 2100RPM max, and I still get quite good temps(35*C or so) I think it'll do much better with my new case...
What i said was technically correct however its kinda pointless to even bother and overvolting fans is never a brilliant idea.Oh and I think Praetor was joking...I think.
ive seen others with thier fans at way higher speeds
Well check the manufacturers specs on the fanand i dont think my fans are at full power.
In that case, buy a better fandont really care about the life of the fan as i can always buy another one or another HSF only if i have to.
But imagine say running 13v through a high flow 120mmNot all fans need speed. Many higher performace fans(particually larger ones) can move more air at lower speeds. My CPU fan runs at about 2100RPM max, and I still get quite good temps(35*C or so) I think it'll do much better with my new case...
While you can compare things like CPU, mobo, fans etc, there's no way to readily convey how much thermalpaste was used or how well lapped a HSF was....oic but the thing i dont get is that the other people i compare with have the same CPU(x2 4200) and use the stock HSF, same as me, but i get higher temps while they are way lower. thats y i want to see/test if the speed of the fan is my problem. b/c it seems low to me when i hear of all these high temps. like you 2100rpm mine is like 900rpm-1000rpm which is way lower.
