Custom PC Parts Help?
cheeseman126
I am looking to build a PC which will be used for HD Video editing using sony vegas pro 10 and the odd bit of gaming (games like starcraft 2) so far I have got these Parts In mind
If you could give me ay suggestions that would be great my budget is under £650/$1000 not inc OS, also could you tell me if I am missing anything like parts or cable which i will need
If it matters i will be running Windows 7 Pro 64-bit
Many Thanks
Toby S
p.s. the quickfind number on the image is for ebuyer.com, if you need to look in more detail at the parts
Consider getting 2x4GB in the US cost difference vs 4x2GB about 13GBP. Certainly not critical but a thought for the future.
^yes, it many be easier on the controller too, and as mentioned slots available to upgrade.
Gskill/Mushkin/A-data memory would be better and they have lower v's. That Corsair is high @1.65
