Well as far as files if u have music or pictures, documents burn them to cds.. then with your xp installation disc.. put it in the drive reboot the computer, if the bios is not set to boot from ur disc drive set it to do so.. then u wanna get into the windows installation its all pretty self explanatory from there, but instead of reapairing windows hit esc, and delete the partition and reformat
well when ur comp turns on it should say toward the bottom of the screen to hit del, esc, f12 f8 something along them lines to boot into bios, upon entering bios find the screen where it allows u to set the boot device priority and set ur cd drive to become priority 1
at the beginning of this thread i thought u said the keyboard works until windows loads then it fails to work
no u want to delete that partition and format it.. during installation when u get to the partition selection u should beable to hit delete i believe, ESC then L or something like that it will tell u.. u want to delete that partition though then format it do a full format also, then install windows
ok well u have a dell right and u used a the dell Os re-install disc that came with it correct.. and also if u have a dell u should have a drivers disc that has the drivers for everything.. and if u cant access internet at this 2nd as long as its the disc that came with ur dell and u used the SN that came with ur dell call the number and activate by phone.
