It can't or won't hold a charge and shocks you if you touch it wrong. (the keyboard doesn't work either, so I use and external one)
I'm just looking for what replasement batteries are compatable and about how much they cost. I doubt it's worth fixing the battery but I might as well look into it and be sure.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&SubCategory=538&N=2000260538
A list of NewEgg's batteries and AC adapters. I just have no idea what would work with my Dell. The AC adapter works fine, but without holding a charge I can't use the comp unpluged during a storm or power outage.
