Desktop build. Need help and opinions.
Jli85
I'm looking to build a desktop on a super tight budget of 200 bucks max. And thes is what I have so far. Anything I did wrong, ect? And I know it's missing a psu and an OS. Essentially I want to be able to do school work and play stuff like cod and bf3 even if they're on the lowest settings. Just want them playable. Lol
1 DIYPC DIY-5823 B/S Black SECC ATX Mid Tower Computer Case with 1 x 80mm Fan
Item #: N82E16811353007
Return Policy: Standard Return Policy -$21.00 Instant
$39.99
$18.99
1 Seagate 9W2005 40GB 7200 RPM IDE Ultra ATA100 / ATA-6 3.5" Internal Hard Drive -
Item #: N82E16822148941
Return Policy: Limited Replacement Only Return Policy -$15.00 Instant
$29.99
$14.99
1 BIOSTAR A780L3B AM3 AMD 760G Micro ATX AMD Motherboard
Item #: N82E16813138329
Return Policy: Standard Return Policy -$10.00 Instant
$49.99
$39.99
1 ASUS EAH5450 SL/DI/512MD3/MG(LP) Radeon HD 5450 512MB 32-bit DDR3 PCI Express 2.1 x16 HDCP Ready Low Profile Ready Video Card
Item #: N82E16814121476R
Return Policy: Open Box Refund Only Return Policy -$12.00 Instant
$32.99
$20.99
1 ASUS Black SATA DVD-ROM Drive Model DVD-E818A7T/BLK/B/GEN
Item #: N82E16827135224
Return Policy: Standard Return Policy $18.99
1 Crucial Ballistix sport 4GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model BLS4G3D1339DS1S00
Item #: N82E16820148538
Return Policy: Memory Standard Return Policy -$5.00 Instant
$22.99
$17.99
1 AMD Athlon 64 X2 4000+ Brisbane 2.1GHz Socket AM2 65W Dual-Core Processor ADO4000IAA5DD
Item #: N82E16819103969
Return Policy: Limited Replacement Only Return Policy -$18.00 Instant
$39.99
$21.99
COD MIGHT be playable on the lowest settings, it's not a hard game. However, most games won't run at all. Go used. Are you buying now?I can pull up some ebay listing's. What tow do you live in?
cpu is too slow, I can't play minecraft on my athlon 64 X2 5000+ which is faster then that one.
Go at least with an AMD Athlon II X2 270 Regor 3.4GHz.
I live in Scranton pa. Is used a really good idea?
Honestly if you're wanting to game and that's your limit, pick up a PS3 or an 360. Gaming at that cost won't get you much of anything.
200 won't get you a decent gaming machine, sorry. Unless you get lucky and find a second hand on eBay from years ago perhaps.
