Desktop Power On Problem
Southy
I have a desktop computer that when I push the power button to turn it on,
the lights and the fans turn on for like 1 second and then it shuts off right
away. Does this mean the power supply is done or is there something else
that maybe the problem?
i think your power supply haved problem. you can try replace a different power suplly
if it is still the same, your computer has a new problem
the Power supply might not be the problem, your motherboard could be shorting out,
how old is the computer??? if it is a new build that could be the problem.
I've had it for almost 2 years now and I custom built it myself. Not quite sure what is going on as it just started doing this out of the blue.
Like cohen said it could possibly be the motherboard or It could be the psu.
I would suggest that you run some kind of test.
