Please help. What is the difference between your cpu temp and system temp. I have a Q6660 and stay in the mid 40s for cpu temp but on nvidia system monitor it says my system temp is 178C How can this be???
You probably have a bad senser. But the System temp usually refers to your motherboards Northbridge Temp. Not what degrees it is inside your computer case! You need to download a couple of temp program to make sure its not just a buggie program.
http://www.sisoftware.net/index.html?dir=dload&location=sware_dl_3264
http://www.cpuid.com/pcwizard.php
