It helps with communication with the intel chip with PCI add-in cards i believe
If its a self built pc the drivers should be on the m/b cd, if prebuilt we need the model and make of the pc
Basically what you need is the chipset drivers. But like said we would need to know what motherboard your using if its a custom built system or make and model of computer if its store bought.
