So I have an LCD monitor and an older flatscreen, and two computers, my older computer, I have set up on the old monitor, and the plan is to put the newer computer on both, but I have a cheap switch that will allow me to switch on the old monitor from old to new computer, with the lcd always having just the new computer on it. Hopefully you are following. My newer computer has a 5770 with 2 dvi ports, on port goes to the new monitor via dvi cable, the other goes to the switch box via vga cable and dvi to vga adapeter, the old computer is hooked to the switch box via vga cable, and the switch box is hooked to the older monitor. At one point I was able to run the new comp on dual monitors no problem, but swapping the cables was a pain, so now I have the switch,
Problem:
but any time I plug the vga cable into the video card on the new computer, neither display shows up, the old monitor is black, and the lcd says no source. I tried restarting and such, whats up? Also, the older display works with the older monitor fine, even with the switch in, but has a flickering issue...
Problem:
