uniquekrishna
Hello All
I am using Excel 2003 and by mistake i have deleted one the file which is important for me after that with the help of a software i have recovered that file but that are in .tmp format and now when i open that one then is shows the error message
"The file you are trying to open is in different format than specified by the file extension."
Kindly tell me is there any way to open that recovered .tmp file in Excel with the formatting.
Thanks
Thanks
