Finding out Temperature for your Computer parts?!
twalker323
What is a good program to find the temperature of your cpu, graphic card, ram? is there any other parts that i should keep a temperature check on? i am completely new to building and maintaining self built computers. Thank you for the help
what is the standard temperature for: cpu, graphics card, ram (and any other parts that i might be forgetting)
You will have to look up idle/load temps of every part of your PC since they dont all run the same. I just dl'ed PC Wizard 08 and it seems like a good program.
I use speedfan, it will tell you the CPU temp and HD temp.. Not sure if it does memory and GFX card, it doesnt do mine, but it might do yours.
HD average temp is 30-40
And CPU is 37-55, someone correct me if im wrong.
Your best bet is use a fan controller that monitors temperature, I use the Kaze Master 5.25” fan controller, it have 4 temperature sensors that you can place anywhere within your system, I place 1 on the CPU between the heat sink and the CPU another on my master hard drive, a 3rd on the GFX card and the 4th I have in the centre of the case open, the display shows the temperature of all the selected areas at any time such as when gaming etc, and the controller then allows you to turn the fans up or down to keep good control over the systems temperature.
