Hey guys,
First post and first PC build! I know a little bit about how to put a system together - probably enough to get myself into trouble, so any help is welcomed!
My budget is around $2100Aud (pretty similar to the US dollar atm) and these are the components that I'm looking at using:
Coolermaster HAF 932 Case
Corsair HX-850 Modular PSU
Corsair H70 Liquid Cooling Unit
Corsair 12GB DDR3 Triple Channel 1600MHz RAM
Gigabyte X58 UD5 Motherboard
Intel Core i7 950 3.06GHz CPU
Hitachi 2TB Sata 7200rpm
Dual Nvidia GTS450 Leadteak Extreme GPU
Corsair Dominator Airflow Fan for RAM
Pioneer SATA DVD+CD/RW 24x Black
Creative Sound Blaster X-Fi Titanium PCIe
Are these components compatible? Any improvements I could make within my budget? (Budget is for the box only, not including monitors, speakers etc etc)
I'm into performance, so anything that will speed the system up I'm interested in. I was thinking SSD for the OS but I don't know enough about them to make an informed decision. If I can get a substantial increase in performace for a slightly higher outlay, then I'm definitely open to it!
Thanks!
Thanks!
