looxztation
Hey, i realy need advice if this is a good spec?
Os - Windows home premium x64 bit http://cdon.se/hemelektronik/windows_7_home_premium_-_svensk_64-bit_oem_(dvd)-7328606
CPU - Intel icore LGA1555 socket i7 2600k http://cdon.se/hemelektronik/intel_core_i7-2600k_box_3,4ghz_%2f8m_s1155-14187779
Motherboard - Fatal1ty P67 Professional http://www.webhallen.com/hardvara/1...ntel_p67-ddr3-3xpci-e-sata_3.0-usb_3.0-firewi
RAM - dont have find some good yet, please post some you will recommend!
Grapics - Navidia MSI GeForce N560GTX-Ti Twin Frozr II/OC 1GB [urlhttp://www.komplett.se/k/ki.aspx?sku=622728][/url]
PSU - XFX Black Edition P1-850B-NLG9 850W http://www.dustinhome.se/pd_5010332450.aspx?csref=Prisjamforelse_Prisjakt_6180
HDD - WESTERN DIGITAL CAVIAR BLACK 750GB 7200RPM SATA/600 64MB [urlhttp://www.dustinhome.se/pd_5010543547.aspx?csref=Prisjamforelse_Prisjakt_5309][/url]
SDD - Crucial RealSSD C300 2.5" 64GB SATA III http://www.komplett.se/k/ki.aspx?sku=601876
CPU Cooler - Corsair Hydro H70 http://www.dustinhome.se/pd_5010465552.aspx?csref=Prisjamforelse_Prisjakt_5328
I want to know what case i will choose this is the exempels!
CM Storm Enfocer
http://www.webhallen.com/hardvara/133294-cm_storm_enforcer-svart
CM Storm Scout
http://www.dustinhome.se/pd_5010330256.aspx?csref=Prisjamforelse_Prisjakt_5294
NZXT Hades
http://cdon.se/hemelektronik/midtower_nzxt_hades_black_midtower-11321391
Or maybe i will choose a HAF coolermaster? please come with a good advice.
What is the best choise?
It is some other quations i want to ask.
1 - Is the LGA 1555 i7 socket good vs LGA 1366 i7 What shell i choose?
2 - Shell i choose a LGA 1555 socket motherboard or LGA 1366 socket motehrboard?
2 - I wondering what is best if i choose a LGA 1366 Gigabyte G1.Guerrilla LGA1366 vs Fatal1ty P67 Professional LGA1555
http://www.amazon.com/ASRock-Fatal1ty-P67-Professional-Motherboard/dp/B004R9PCLW/ref=sr_1_1?ie=UTF8&s=electronics&qid=1305317019&sr=1-1
Here is Fatal1ty P67 Professional
http://www.amazon.com/Gigabyte-Intel-DDR3-Motherboard-GA-G1-GUERRILLA/dp/B004RAZY3M/ref=sr_1_1?ie=UTF8&s=electronics&qid=1305316955&sr=8-1
Here is Gigabyte G1.Guerrilla
Thanks for all!
The price is about about 1200€, 1725$ and about 11000kr
Thanks for responding!
CM Storm Enfocer
CM Storm Scout
NZXT Hades
Thanks for all!
