first build-need help
kesjc
I want to try and build my first computer. I would appreciate any comments or suggestions with these components. thanks
COOLER MASTER HAF 932 Black RC-932-KWN3 Black Steel ATX Full Tower Computer Case
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare
ASUS VH242H Black 23.6" 5ms HDMI Full 1080P Widescreen LCD Monitor
GIGABYTE GA-870A-UD3 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
XFX HD-567X-YNFC Radeon HD 5670 (Redwood) 512MB 128-bit DDR5 PCI Express 2.1 x16 HDCP Ready
CORSAIR CMPSU-550VX 550W ATX12V V2.2 SLI Ready CrossFire Ready 80 PLUS Certified Active PFC
OCZ Reaper Edition 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model OCZ3RPR1333C9LV8GK
AMD Phenom II X4 945 Deneb 3.0GHz Socket AM3 95W Quad-Core Desktop Processor HDX945WFGMBOX
ARCTIC COOLING Freezer 64 Pro 92mm Ceramic CPU Cooler
LG Black Blu-ray Disc Combo SATA Model UH10LS20 LightScribe Support
Im a Novice myself but I can help you out a little since ive been looking at this stuff for a couple weeks now and these are things ive looked over and chose for my future PC.
First off you can spend a few more bucks (like 4) and get the 880 motherboard with onboard graphics as a back-up to discrete graphics.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128444
Also if your going to overclock then spend the extra 20 bucks and get the Black edition 955 which is easier to overclock then the 945 .
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
You dont need that much RAM really 4GB will be enough and even though the motherboard says 1333 you can use 1600 it will load as 1333 but you can just change the settings in the BIOS for it to run at 1600.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
A couple more things if your gonna get an after market Heatsink you should get good Thermal Compound also. The monitor, heatsink, blu-ray drive, and hard drive should be fine but you might want to bump up the PSU to the 650 ($10 more or same with rebate) if you plan on using crossfire in the future (allows for either 6 pin or 8 pin graphics cards also). I know nothing of graphics cards so i cant help there. The only other thought i have is that you probably dont need a full tower, a mid tower should be fine and will save you some money. The one im looking at getting is this one VV though you can get something nicer if you like.
Thermal Compound
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
Possible PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
I ordered my CPU from new egg. It was a Phenom II black edition 3.0ghz. The heat sink that comes with it is made for it and it works really well. I would suggest spending the money on a better mother board. When it comes to building a PC you can try and cut corners here and there, but when it comes down to it you want to get the best mother board & CPU you can afford. Or you can spend that money on this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727&cm_re=phenom_II-_-19-103-727-_-Product
case - CM RC-932-KWN3 is big and expensive. Drop to a cheaper case and invest the money for better video card
http://www.newegg.com/Product/Produ...1119215&cm_re=CM_690II-_-11-119-215-_-Product
http://www.newegg.com/Product/Produ...6&cm_re=cm_storm_scout-_-11-119-196-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197&cm_re=cm_922-_-11-119-197-_-Product
CPU - Phenom IIx4 955 if you overclock
RAM - 2 x 2 GB usaually enough
Video card - Get 5770 1GB instead
PSU - Good, but there are better for same price
http://www.newegg.com/Product/Produ...096&cm_re=seasonic_620-_-17-151-096-_-Product
Heatsink - ARCTIC COOLING Freezer 64 Pro is not really good
Scythe SCMG-2100/ XIGMATEK HDT-S1283/ ARCTIC COOLING Freezer 7 Pro Rev.2
are better.
